What cases have you found?
Is the dbrand skin thick enough to protect cameras when placed on table?
No, it is a SKIN, and thus, paper thin. If you want, and what I have seen done by some, is get a nice case and DBrand the case. :P
Not perfect and needs some tweaking for the fit, but if done right, looks okay. :D
I have yet to find a case that doesnt have the edges raised too high especially for swiping on the front of phone. And the case edges sticking out further on the top screen vs the bottem when the phone is folded which feels weird. Smh
I really like the Samsung Aramid case. Feels great. In regards to my spen and where I am putting that, I was one of those crazy people using a Surface Duo prior to this. Have a surface pen for that which I kept in a pouch of sorts. Now going to use that for the spen as it fits in there perfectly well. (Still have the Duo, but probably will not need it with the fold now. The Duo 2 that is coming looks horrible with the camera bump on the back in my opinion.)
Do you have a link for this?
I found this Casemate w/hinge protection at my local AT&T store yesterday. It seems pretty protective and for $45 I'm satisfied. It does make the already big device bigger but the protection is there.
https://forums.androidcentral.com/e...h-black-plus-galaxy-z-fold3-5g&token=FTCWh0VY
I had this case and it started to lift the front screen protector after few days (because no adhesive causes top part to slide a little on unfolding). But the worst part, I couldn't take it off. Took me multiple attempts and very long time (and too much anxiety). One guy on Amazon damaged his phone while removing this case. I sent it back. Waiting on Spigen case with a hinge protector.
I had this case and it started to lift the from screen protector after few days (because no adhesive causes top part to slide a little on unfolding). But the worst part, I couldn't take it off. Took me multiple attempts and very long time (and too much anxiety). One guy on Amazon damaged his phone while removing this case. I sent it back. Waiting on Spigen case with a hinge protector.
It IS a beeatch to take off I know, right. The part about it lifting the screen protector does not sound good. Hmmm....
If your screen protector is fine, and you don't plan to take this case off often, keep it. Just be very careful with taking it off. A lot of patience. I just was worried so see the top part sliding a little bit. Over long time may scratch the phone body as well. It does offer a lot of protection.
I change cases and SIMS often so a case that is reluctant (or worse) to be removed is not gonna work for me. I'm taking it back. I'm not go na risk damaging a $1.8K device with a $45 case. I should've known it was too good to be true.
Well I wasn't going to get a case but since I had that small mishap with the drop picked up the Samsung silicon...I think it's a nice fit and my front edge panel and swipes work nicely... I'm going to switch between naked and this puppy ...
Has anyone found any hinge protector film sold by itself and not with screen protectors?
tahirmehmoodkhokhar786
