What is the best case/screen protector combo for the s7 edge?
  • Start date Start date
A
Android Central Question
I currently have the supcase unicorn beetle case on my s7 edge and I've tried 4 tempered glass screen protectors and the case cracked all 4. I'm wondering what the best case/screen protector combo I can get is? Do I want dual layer, a flip case, or something else? I'm mostly concerned about the screen above all else. The screen needs more protection than the edges or back. Any suggestions welcome!
I'm using the same case (Pro) with the GPEL glass screen protector and have had NO problems whatsoever.
I'm using the unicorn beetle pro case with Pleson screen protector. Really like that combo. Tight fit but works as long as you don't keep taking the case off.
Could you give me the links for both the Pleson Screen Protector and the Unicorn Beetle Pro Case?
Am coming up with a lot of similar results and not sure which is the right one.
thanks
AnonymousVPN
