What is the difference between a hard and soft brick?
guys i was trying to do a backup in CWM recovery and then i reset my galaxy core to factory settings then it was stucked in CWM menu and now when i start my cell thr is a yello logo triangle whatever u call it and then my cell goes to recovery option what should i do ihve tried factory reset.....but problem is still there my phone is in recovery menu is this is a hard brick please help....!!
Hi Friend !! Dnt worry Since Ur phone Is still booting in Cmw Recovery Den Ur phone has suffered Soft brick n U can recover easily . As u had done the Factory. Data Reset all Ur app data internal storage and every thing has wiped .. So in order to recover Ur phn U need To go to Cmw and Mount Ur flasable rom (Original Rom) in SD card and Den wipe portion and Den flash it.. After DAT Ur phone will reboot and U r ready to Rock :)
hi , can you help me get ride off problem
i had rooted my karbonn s5 n it successfull rooted that ok
after that i had installed various apps
superuser, cleaner etc,
and i also installed "chainfire 3d" and i had give permission to superuser to root access
and again i had given the permission to chainfire 3d to root access
then my phone gone to booting
for 1 to 2 minutes
and i taken out battery
and kept again
now the phone is not opening ie only showing booting screen
please help me
my phone model is karbonn titanium s5 andriod version 4.1.0 jelly bean
pls help me i bought it just 5 months before
pls help me
Try booting in Cmw/ Twrp and Factory Reset and wipe cache delvick cache internal storage data and Den flash the original rom !! I suffered the same problem Giving permisioon both Super Su and Super User and phn gone in bootloop .m dnt wory U r f9 U will recover
what do you mean by dirty flash
a dirty flash is a improper rom/iso (both are phone bootable hard and software ) that isn't ment for your phone it's also a rom(or ISO which ever you want to call it ) that's broken or incomplete like a incomplete app from any app store
Hello, my phone (lenovo a369i) was stuck on the lenovo logo and nothing was happening so I wanted to flash my phone and downloaded the smart phone flash software and launched it. Then I followed all steps and I clicked the download button within the software after some time there was some power issue with my PC so the process was not completed. After that when I tried to open my mobile it was not opening and even the lenovo brand was not displaying now but was displaying before.
I think this is due to the incomplete process which killed my phone. So now my mobile is not opening and not showing the lenovo logo also are there any chances to repair my mobile.
I was given an Android phone from my cousin that he said he had tried to flash it and used the wrong software and now the phone will not come on at all...is it fixable? If so how?
for 1 to 2 minutes
and kept again
please help me
pls help me
Its very simple get to a pc and flash a new rom either custom or stock and flash it with your phone model's usb driver but if you had not backuped your data then there is no way to recover i just soft bricked my phone but i flashed a rom and my phone get started
Re: Difference between hard and soft brick
A dirty flash is when you already flashed a ROM, let's say Cyanogenmod 11 (KitKat), and then without doing a data/factory reset in the recovery, you flash a newer ROM on it (let's say Cyanogenmod 12 (Lolipop)). SOMETIMES this can work, but 95% of the time it won't without glitches.
This won't kill your device, merely a chance for a softbrick. When that happens, you just go to the bootloader > recovery and then data/factory reset, and you install the newer ROM.
You will lose your apps and data, though, that's why some people try a dirty flash first.
I did a dirty flash on my phone and it hard-bricked it, not soft-bricked.
I face this problem too, I try to uninstall Xposed Firmware but It boot me in to Recovery mode (I use TWRP). When I try to reboot again, It always boot me in to recovery mode.
But i can fixed, I flash rom with official firmware that change Custom Recovery to Official Recovery. Thats mean, You device is only soft-brick not Hard-brick.
Someone help me I tryed rooting my Samsung galaxy tab 4 and it worked but a bunch of stuff kept popping up like "unfortunately ... has stopped working" so I shut it down and turn it on and it froze on the startup screen is it bricked??
nwnjzp42432e
