What keyboard does every one use?
Yep, same here. No comma without going into the symbol menu is a dealbreaker for me. I use Swiftkey, but wish it had the awesome number keys on the top row the same as stock.
No need to do that, just long press the n key
I have used SwiftKey on all my Android devices.
It just works for me and I am extremely used to it.
Sent from my Galaxy Note 3
I use Swiftkey. Which I love but the predictions stinks. And sometimes it likes adding more words that I've typed out. Hard to explain but act weird. Could be that I'm using the Beta one.
Sent From My Samsung Note 3
SwiftKey all the way. I try out new ones now and again but it just keeps drawing me back. Amazing keyboard.
SwiftKey, I've normally found the stock keyboard the most responsive but flawed in some way but on the SGS5 SwiftKey is faster than stock.
I do keep swapping around from time to time between SwiftKey, Swype, Google Keyboard and Touchpal X
I was a big proponent of the Google keyboard until I get a 7" tablet. The tablet version of the Google keyboard needs a lot of work. So I installed SwiftKey on my tablet. Then I got tired of using different keyboards on different devices, so I'm a SwiftKey user on all my devices now.
SwiftKey. I've tried them all but SwiftKey is the best in my opinion.
Sent from my SM-N900V using Tapatalk
Can someone help me? If I keep pressing the space bar random words will be entered. I thought it's only supposed to predict words I mistyped.
Here's an example, keep in mind I'm just pressing the space bar on the SwiftKey app: the best of luck to you by the way to get the best of luck to you by the way to get the best of luck to you by the way to get the best of luck to you by the way to get the best of luck to you by the way to get the
See? Just random words appear when hitting the space bar! Ugh.
I'm all about Swype. I kept trying Swiftkey but don't think the swyping is accurate and I don't like to tap on my SN3
Sent from my SAMSUNG-SM-N900A using Tapatalk
There is a setting for what you want the space bar to do. Three choices I believe. Settings/advanced.
yanis
