What Replacement Phone Have You Decided On?
I think this phone will be awesome if enough people get it that the dev community picks up, keep flaunting it!
Main difference is the lg has a 5.7 ips display vs a 5.5 amoled on the axon, removable battery and probably better camera in the lg, but the axon is half price.
Thanks, i just looked at the specs on best buy. Does it have expandable memory?
I am getting the 64 gig Note. Changed my mind on keeping 32gig..Verizon has ordered for me
AT&T Note 5 phones are now available for order on Samsung.com. Just placed an order for a black 64gb. Didn't want to be without the spen. I assume that once I have it in hand, I can walk into the AT&T store, return the note 7, and activate my note 5. The real question is if I can get the $100 credit.
I know Verizon is giving 100 credit. You should because you are getting another Samsung. . I am using the Note5 32gig right now. Thought I could deal with smaller amounts of gig but I can't. So ordered the 64. Won't have till 15th..veruzon out of it.
I like the Note 5. It's very smooth and fast
My Axon 7 will be here on Tuesday. $399 no tax free shipping from NewEgg
On Thursday I blew $299 on a Motorola G4+ so I'd have something to root and try different ROMs on. It's not a bad phone but now I'm thinking I could do quite a bit better if I just wasted $100 more. The SD617 in the G4+ is nothing to write home about.
Yeah, I definitely need the 64gb too since the note 5 has no SD.
I have "settled" for the S7e; I want/need expandable memory, so that nixed the Note 5. I will probably make extra payments each month to pay off the S7e early so I can be upgradable for the next, hopefully, iteration of the Note.
Does any other carrier have the no stock in black s7 edge issue besides Tmobile
Would had done the S7 and not the edge. I don't like the edge. Ran very hot. Screen too curved
I'd buy that in a heartbeat.
You would be disappointed. 32 bit apps are not going to be suited for a phone form factor.
People want Instagram, Snapchat, Tinder, and the multitude of other apps they're accustomed to in iOS and Android.
If this report is true then there's no hope for Microsoft in mobile, they truly don't understand customer needs.
What is missing besides the SD card and the curved edges and iris?
Waterproofing and the ability to use the phone and stylus in rain.. The bigger battery. How easy it is to plug in USB-c cables.The very feel of the device. The thoughtful touches of Grace UI that made you not have to leave what you were doing to switch wifi networks....stuff like that...
Like I said, I'd buy it in a heartbeat. Put my Surface tablet in a pocketable form factor and that would be perfect.
dumpsterrentals91
