What's best way to do soft reset? Ultra S22 phone
Casey Cheung
1,234
5
On my old Note 10+, I could hold down the power button for a few seconds which will then display a few choices of turning off phone, doing a soft reset, etc. My Ultra S22 doesn't do this anymore. So what's an easy way of doing a soft reset?
Thanks! -Casey
Make sure Bixby not enable for side key, go to settings>advance features>side key >power offScreenshot_20220619-213559_Settings.jpg
The best way in my opinion is to swipe the notification panel down twice to get to quick settings and then tap the power symbol.
you can also just hold volume down and the side key (the key that used to be the power button) to get the power menu.
I don't like changing the side key function because I consider the power menu a waste of a key.
tjp5p8l1xf
