Whats Revolutionary About iPhone 5?
Oh. Ignore previous post. So why didn't you get the GS3 or something, I don't understand how anyone can go from stock Android to iOS and not have a brain aneurism from rage.
Sent from my One X using Android Central Forums
Lol. No problem. I had gotten the GNex at launch. Had major radio issues, and the camera was pure crap.
As the end of January approached, I had to make a decision. I knew I couldn't keep it, nor did I want to keep getting replacements. So I ditched it.
I've never had an iPhone, so I decided to give it a try. I must say (and I have) It's a nice device. It's smooth, responsive & gives me zero issues.
Will I buy another iPhone? I'm not sure. Will I buy another Android device? Probably. I think I'm going to make a pit stop with WP8 before then. The Lumia 920 really appeals to me. To each his own.
It is a fact the Verizon version of the gnex has radio issues. That ti omap doesn't like lte very much I hear
Sent from my HTC Vivid using Tapatalk 2
The DROID RAZR and RAZR MAXX have OMAPs as well (though not the exact same one, I think the one in the Galaxy Nexus has a better GPU) and they're not known for poor radios.
The OMAP processor has exactly nothing to do with radio performance.
Sent from my SCH-I535 using Tapatalk 2
Well my buddy had the bionic and it's almost identical to the guts in the gnex and he was having signal issues like crazy and he swapped it for a gnex only to have the same issues. From what I've seen only qualcomm can make decent lte socs
I have the Razr and have NOT had any issues at all besides a few on the software end (for some reason the phone decides to put in the notification bar that it has no signal but if I go into settings<more<mobile networks<network type and strength it will show it has signal but if I try to load up a webpage it says cannot connect. Weird huh..?)
BobCat6767
