Which Headphones....
Does something pop up In The notification shade when high impedance mode is active? I don't see anything telling me which mode they are in when I use the B&O's
It shows in the hi fi dac switch setting. Once you plug in your headphones it will show normal or high impedance.
Well in that case I haven't been able to get my B&O's to play in High impedance.....When I went to the Dac settings it said normal
People are saying there is a wax coating on the headphone plug. See if there is and if removing it helps. Many saying that resolves the issue.
It's the coating that makes them false trigger high impedance. Not the other way around.
For home use I am using Sennheiser Momentum 2.0 over ear headphones and when out and about and at the gym I use Xiaomi Mi Piston V3s. Both sound terrific with this phone and the Momentums are SO comfy!
I purchased these 1MORE headphones 2 months ago. They were Consumer Reports #1 rated. They sound great to me and my ears and are fully braided wires for extra durability.These earphones a high quality complete with many different size ear buds in a very, very nice magnetic carrying case. The quality is all there. Bass lovers will be disappointed thou IMHO. $99 on Amazon. Nothing beats a good quality full set of over the ear headphones.
Bass lovers will be disappointed thou IMHO. Nothing beats a good quality full set of over the ear headphones.
The bass I found it is highly dependent on the seal you can find. Trying different buds to find the right level for me.
Can anyone recommend a set of in-ear headphones that are 50 ohms? I would like to ensure the high impedance setting is triggered but without the bulk of over the ear phones.
Check out https://forums.androidcentral.com/e...s%3A%2F%2Fwww.urbanears.com%2F&token=AtHrJaTO
they have a complete product line, build quality is excellent and they truly sound great. I discovered this outfit a couple of years back when I was doing a similar search. Been using mine for more than a year and use them all the time. Truly excellent value and superb quality.
Thanks but i need 50 ohm to drive the dac. Looks like the klipsch do it.
Although they make great speakers, they're earphones aren't the greatest. had a pair about 2 years ago, but they lasted 16 months, one side stopped working altogether. I requested a replacement from Klipsch, but they insisted only 1 year. Ordinarily I wouldn't be to ticked, but I paid $130, so you bet I was ticked.
well lets see what they're like. i ordered the X12i which seem really expensive to me at least but has got good reviews. I didn't want to pay that much but there isn't much to choose from if you want 50 ohm.
MichaelCrusan
