Which rooting procedure will be best for my device?
A
AC Question
I have a china-made device, Qmobile. I am not sure as to which procedure should I follow. My device has pretty good hardware and runs Lollipop 5.0 by default. Can anyone please tell me that, to root my device, I should follow instructions for which populor device?
AlphaTango414
3,939
95
Most all devices gain root access by different loopholes and not very many are for broad phones. I'd tread very carefully of you try to root, as your chances of bricking the device is much higher than most other people. Try at your own risk.
I'd recommend staying away from rooting but if you are willing to take the risk and have your mind set on rooting the device, IMO best bet would be Kingroot. It's a one click root script.
Good luck.
Abhishek397
