Who has NOT received an OTA yet?
5.0 check, Still waiting 5.0.1. Phone is Nexus 5, some problems with new flashlight and camera crashes sometimes...
this method worked for me on second try. it will probably temporarily break your GCM (Google Cloud Messaging) Push Email/Notifications and you will have to do a hard reset back to factory fresh state and then manually resync and reinstall of all apps and data in order to fix it - so make sure all of your data is backed up first. a PIA but a clean fresh start from scratch is not a bad idea anyway when doing a major OS Letter update. good luck.
Pradaman Shorey
Shared publicly - 2:31 PM
#Nexus5
How to force Lollipop Update on your Nexus Device:
1. Go to Settings > Apps > All > Google play services > manage space >
clear data.
2. Go to Google Services framework > clear data > force stop.
3. Go to Settings > About phone > system updates (it should say last
checked in 1969)
4. Click on 'Check Now' & keep refreshing and it should push the
update to your phone if it doesn't work the first time keep trying.
It worked for me in the first go (Nexus 5)!!
Good Luck...
#lollipopupdate #nexus #update #nexus5 #lollipop
#google
https://plus.google.com/+PradamanShorey/posts/RhmXWhoE6Be
Force Android OS OTA Update
Same here. Already got OTA on MotoX PE and Nexus 5 (for few weeks now).
There must be something going on behind the scenes with the slow rollouts-maybe
Guy from the Philippines checking in here. Still nothing. Maybe it has to do with some of the odd bits and ends that people are finding wrong with the initial Lollipop rollout?
If I understand correctly, some folks who still haven't gotten 5.0 at the moment may likely go right to 5.0.1 due to some fixes that Google want to get in before a wider rollout., as some have pointed out.
That is exactly what I'm thinking. I've NEVER had to wait a MONTH for an update. I usually get it within 3-4 days.
I think you will receive it soon, I received 5.0.1 on Thursday and it seems to be working well. Hang in there.:)
I just got 5.0.1 and so far so good, no problems at all. It's runs smooth.
Finally got the update from Kitkat. On 5.0.1 now by doing the framework trick and restarting my tablet.
Did a factory reset and it feels like a whole new tablet. I was getting multiple random restarts a day on Kitkat and haven't had one since I updated last night.
Still have not gotten an update yet on either my 2012 or 2013 Nexus 7's
What Framework trick?
Still waiting for the update on my 2013 LTE nexus 7. The old Wi-Fi 2012 I've got as well hasn't gotten it yet.
tinni99
