Who is crazy about battery life?
I didn't drain it all the way down (had to toss it on the charger for tonight), but the results are pretty clear. At the rate it was draining (texts as well - ~50) it would've gone for about another 45 minutes of pure streaming. The wifi active was from when I pulled it off the charger this morning (and my commute) before I started the test. I think the battery was between 95-97% when I started. 4G the entire time while streaming watchespn (only used 2.5gb of data):
I figured I would show you what type of battery I received today. I was on Wi-Fi at all times so keep that in mind.
Sent from my Motorola Droid Maxx using Tapatalk 4
using the things that i have on my phone I have been getting awesome battery life with my maxx I am currently at 89% and have been unplugged for 10 hours and 38 mins :)
Google+ was killing my battery. Once I disabled it, I get great battery life. Make sure you are not using Google+.
What if I just turned sync off for this - would that accomplish the same thing as disabling the app in terms of saving battery? Or would I have to disable it to see any benefit ... ?
