Why do I have oversized System Data on Huawei P6 after updating to KitKat?
  • Start date Start date
A
AC Question
Oversized "System Data" on Huawei P6 after updating to KitKat
My friend helped me to update from 4.2 to 4.4 using the exact same ROM flash process he used on his P6 with the same international firmware.
I am aware that the internal storage is 8GB, and that it is split in half, one half for Android OS and the other 4GB is for your own use. I will only be referring to the latter 4GB. I also have a 16GB SD card but it's not of much releveance other than almost all my media and apps being transferred to it.
After being updated to 4.4, I soon noticed I kept running out of space despite everything possible being on my SD.
Using the DiskUsage app, I discovered that almost 3GB of my internal 4GB storage is taken up by "System Data". I confirmed this as being unusual by comparing with friends' phones (also P6, both 4.2 and 4.4)
My phone is not rooted, and we used international firmware with a tweak to allow Google Apps to work correctly
Re: Oversized "System Data" on Huawei P6 after updating to KitKat
Could be that you need to do a factor reset to get the OS back in order? Could be the phone didn't partition correctly when it installed the ROM.
Hi this is OP.
Can you please explain this process?
My internal storage is now 100% full :/
Hi, this is said friend with P6. It is true as he says, except it is not 'international', but 'chinese' firmware, hence the 'tweaked' (flashed) google apps that work. I gathered as much that a partition created itself, but I have no idea why it did so. My P6 did not, and functions fine. How would one get rid of the partition?
Factory reset did the trick.
Though I still have no idea what all that "System data" was O.o
Garbage that the system stored "temporarily" while it was setting up (and didn't remove).
