Why does my battery indicator not give honest measurement?
  • Start date Start date
A
AC Question
I have a Samsung Galaxy Note 4 running 5.1.1 and have been experiencing incorrect battery life measurement. My battery meter will say I have anywhere from 15-35% battery life left, then the phone will shut off and restart, when it comes back on the battery meter will now register 0-1%. Any reasons why I'm experiencing this issue? And are there any known fixes?
Welcome to Android Central! The battery might be defective or failing. Does it drain quickly, or charge up slowly and heat up a lot?
The battery software might also be a bit off. You can try calibrating it by charging up fully, then using it until it shuts off. Do this about 3 times, and see if it becomes more accurate after that.
amaka
