Why does the 'none' option not exist for turning off the lock screen on Galaxy Note 3?
If you have a security app active on your device it may require a screen lock. I disabled VZW Support and Protect on my device and it changed from being unavailable to being an available option.:p
FFFFFFFFOUNDDDD THE SOLUTION BOYS!!
The issue seems to be with the actual guest "session".*
1- Go into your phone as the guest
2- then go to user's panel from the quick settings
3- instead of choosing your main user account to switch back to, select "remove Guest"
4- problem solved.*
4- problem solved.*
This worked for me👍
Crissy Doug
