Why doesn't my Note 4 work after drop?
Jul 1, 2015
17
This problem occurred before too. After dropping it from my hand, the display went pure black/blank. Removed the battery, tried to turn it on. Holding down the power button causes the LED to light up(just as it does while turning on), vibrates a little bit but that's it. Nothing more . No sound, nothing.
I tried :
*Accessing Recovery & Download mode
*Hold down the power button for a minute with the battery removed
*Called my number but it says turned off
*Charge
*Connect to PC
Note : This happened before but automatically got fixed after a few hours. But this time, it's the same after a day.
Took it to a service centre but they claimed that the display's broken and I've to pay 'bout $200 to replace it. But I really don't think display's the problem here cuz as I mentioned, it happened before and the phone's not working.
Yeah sounds like your lcd is screwed. It may not look like it but your entire screen has been knocked out and needs to be replaced.
Sounds like this second drop may have knocked a connector loose or something.
Taylor Bag
