Why I think 2013 is going to be the peak for a while
The more RAM they put in just for the sake of it, the more they squander and use inefficiently. The core systems and apps need to stop hogging up resources. I put my GS3 in airplane mode fully charged, turned it on 8 hours later and it was down to 88% and when I looked at the stats it was the media center (or something like that) that used up the battery. What the hell could need to be running when its in airplane mode and sitting idle?
The same argument was valid when phones started using 1 gig for ram and it will be valid when we're debating I gigs over 4 gigs. I'm just saying we're not that far away from the next bump up in ram
Sent from my Note 2
Android personally, I think a bit more RAM would help.
Less lag, would be great.
Octa core CPUs are great and all, but RAM would help more.
Sent from my MZ604 using Android Central Forums
RAM is fine, the octa is using 2GB of DDR3 RAM so really jts one of the fastest rams on an android device, the s3 uses 1gb of ddr2 and I find hardly any lag, so with faster ram, and 2gb it should be fine
Sent from my GT-I9300 using Tapatalk 2
1 GB of RAM with a dual core CPU also caused problems with me. The device would lag, on and on.
The S4 seems pretty fast, and those specs wont lie.
