Why is my Note 4 overheating?
Re: note 4 overheating
Again i charge my phone ,no over heating by fast charging ,fast charger take 30 mins to charger 45% . Here are some screenshot after recharge .
Screen on time
Hi All,
I bought Samsung note 4 few days back and it gets warm while using camera, in particular while using front camera. It gets warm around camera, display and at also at back. Is this normal ? i catched around 30 pics in 5 mins and this issue is reproducible.
Sad thing about this is, I have had three or four devices..... All of which do the same thing, overheat after having it two or three weeks. Terrible. Goodbye Samsung technology.
Are you saying that you got your carrier or Samsung to give you 3 replacement Galaxy Note 4 phones when your original started reheating, and all of them have had the same problem?
I offered some suggestions in the thread you started.
i have had my note 4 for over a year never had a problem untill about 3 months ago when sending texts to my husband it kept freezing but only messages to him very odd. then it suddenly turned off after doing this for two weeks, when i turned it back on it said it had overheated, yet it never felt hot. switched it off for 24hours with battery out then factory reset it and i thought problem solved. however it has started again this time nothing i do fixes it after it being on for half an hour it says it is overheating and powers down the phone. if this is a common fault with the note 4 i may be going to buy a different phone in the morning.
also my battery has not drained and is fine. i have just used the new update before the problem re occured.
CliffHangerOld
