Why red battery icon and screen dim quickly?
Aug 14, 2022
6
Ive got a new Doogee S40 running Android 9.0.
A problem started when battery level went down to 20%. The battery icon started to be outlined in red and the screen started dimming after around 5 seconds.
I ensured the following:
a) Screen saver was and is 2 minutes
b) Battery Saver is off
c) Battery Manager is off
d) Standby Intelligent Power Saving is off
I have restarted the phone more than 5 times since this began. There has been no change in the red outline or screen fading.
Welcome to AC!
When battery indicator goes in red it sounds like it went into battery save mode even if you have it off , can you adjust the brightness slider up?
At least you can move the brightness up or down, when do u usually start charging the device again?
SUCCESS! Thanks for the idea of Safe Mode. I found the app "Power Saving Mode" and sure enough, it was in "Super Mode" so I changed it to "Normal" and the phone righted itself!
Glad you found the problem! Is this a 3rd party app that you installed, or something that came with the phone?
amaka
