Wi-Fi Problem
craZhorse
Active member
Jan 18, 2011
38
So I flashed the latest ICS leak and everything runs very smooth except for Wi-Fi. The phone just will not connect to my home network. I had no problems with Gengerbread on the phone, but ICS is presenting a problem. Has anyone experienced this with the latest leak, and if so was it correctable? Thanks.
Did u try a factory reset,I had to do it to mine.
sent from my ics equipped REZOUND
Yeah,it sucks but I gave it a try and I got my data signal and WiFi back after doing so.
Try the reset. The way I understand it the reset should not fix anything after an ruu because the RUU rewrites everything, but it works for some ppl. Go figure
Sent from my ADR6425LVW
Are u able to see possible networks in your WiFi settings?may have to try forgetting your network then retype your password.just trying to come up with small fixes for ya...
well I did the factory reset, but unfortunately it is still a no go. It will not authenticate my passphrase/password. Any other suggestions? I sorta felt something would go wrong while I was flashing this morning. I think I will try to into the router and get a new passphrase. Don't know if that is even possible or not but gotta try something.
What kind of router do u have?I might b able to help u.
The router is a Linksys. I changed the password and tried to connect again but it would not. I was in a coffee shop this morning and had no trouble connecting to their public wi-fi, so something is amiss wi.th my home network, My smart tv. will connect to my network with no trouble at all. It comes down to the phone not authenicating my password. Strange
Just my laptop and tv. Everything worked fine until the leak flash. Wondering if flashing twice more will correct the problem.
ok this is going to seem complicated but isnt
go to start and in the search box type CMD. It will come up with a file named cd.exe
a black window will pop up with a dos prompt
type in ipconfig
a bunch of stuff will come up and most of it you will not need. What we need is
ipv4 address (example: 192.168.1.5)
subnetmask (should be 255.255.255.0)
default gateway (example: 192.168.1.1)
Write these things down.
Now lets go to the phone go into wifi in the system settings menu. The first thing we will check is if you are set to DHCP. Press and hold the network nae you are trying to connect to. a dialog will pop up to either forget the network or modify. Choose modify
click show advanced options
under proxy it should say none, under ip settings it should say DHCP. It either of these say something different, set them to what I have above and try to connect. If it connects, forget everything else I am going to type because we found the issue.
If they say that and you still cannot connect, change DHCP to static.
Here is where those numbers we wrote down come into play. under IP address we want to increase the last digit by 2 from the number we wrote down above (the example: 192.168.1.5 changes to 192.168.1.7)
under gateway, we want that to be the same as the number above (example: 192.168.1.1)
If the rest of the settings are filled in, leave them as is. If not, here are my settings to try:
network prefix: 24
dns1: (the same as your gateway above)
dns2: 71.242.0.12
key index 1
hit save and hopefully it connects.
If not, I got nothing else. I will be here all afternoon if you have a question
Reactions: craZhorse
Finally I got wi-fi to work on my phone. What I did was create a new network SSID , then went into Linksys IP address and made correction for the new SSID. On the phone, in wi-fi advanced setting, I used the router security push button and the phone found the network. All of this took me about 3 frigging hours LOL
