Wifi connection issue- TB Proprietary Channel?
sdepace
4
I have an HTC One M8 on Sprint that consistently connects to "TB Proprietary Channel .eG" instead of my Verizon router for Wifi. The only way to get it to connect is to restart the phone. It's become very annoying. Any ideas?
Thanks
1) To connect to the Verizon router, just tap that connection. It'll give you the choice of connecting or forgetting. Connect.
2) Long press the TB network and Forget.
(If the TB network is unsecured [no password] and it's stronger than your Verizon signal, that's the one the phone will preferentially connect to.)
Thanks but that's not it. First, I can be standing right next to the Verizon router and it still won't work. Secondly the "TB" network doesn't act like a normal network as there isn't an option to forget the network like there is for the rest.
Is there any chance TB stands for my sons Turtle Beach wireless headset? If so is there a way to fix this?
TB Proprietary Channel (Turtle Bay Headset) messing with WIFI conneted devices
It is the wireless headset and I'm having the same problem!!! Its disrupting my phone and all of my Chrome Cast's in the house. Anyone have a solution?
Re: TB Proprietary Channel (Turtle Bay Headset) messing with WIFI conneted devices
Unplug the unit turns off that TB Connection I'm not sure why you guys r connecting to it mine requires a password and I don't have one so I don't have to worry about it. Also maybe activating developer options on your Android will help with how your phone connects to Wi-Fi but never tried
Hollytryx
