Wifi is "saved, secured" but won't connect no matter what
hi poushi... just switch off ur wifi connectio on your phone. then switch the phone off too.e the
take the battery out... put it back in..
now unplug the router from its wire/cable. switch it off.
let it remain off for a good 4-5 min.
now switch it on and give it again good4-5 min to get fully functional state.
now switch ur phon ON.. switch on ur wifi....
it should automatically get connected.
Check that the password for 2.4ghz and 5 ghz are the same in your wifi settings for your router.
this is a lot, but maybe it will help someone.
OK, I called AT&T and the rep I chatted with was helpful. We agreed that it seemed to be a device issue. So I worked with my device for over 2 hours now. I have McAfee instsalled (has been for over a year and the device connected for 6 months - the problem has been for the past month - at least) on the SAMSUNG phone and what I did was to change the McAfee setting on the device limit to a higher number (it was on 2GB and I changed it to 5GB - my verizon plan only has 4GB) When I did this, I got the wifi icon at top of the phone, on the notification bar. Dunno if this change itself solved the issue or if something else changed somewhere else (like maybewith the ATT router/modem); cause I then changed it back to 2GB but the wifi icon stayed. Also location is off and Auto Network Switch is UNCHECKED and "Keep Wi-Fi on during sleep" is set to "Always" and I turned Powersaving mode off, but just turned it back on. Also, as I was "playing" I turned off the following: Samsung Link, Samsung Print Service Plugin, Sansung Push Service, ans S Suggest as I remember playing with and updating this trhu google play when the wifi initially disappeared. Also McAfee was not happy with NFL Mobile app (said it had too much control in my phone) - I don't even understand football, so I know I did not install it. So I turned this off (Force Stop) and disabled it but can't uninstall it - with McAfee nor with the Samsung phone.
So the wifi icon appears, but if it disappears again I will contact this forum. But, for now I have wi-fi. :-) Will see how long it lasts. For those with this problem, there is also good advice (a variety of possible fixes) at this address for Android Central (forums.androidcentral.com):
http://forums.androidcentral.com/sa...cured-but-won-t-connect-no-matter-what-4.html
Just a note, although I can now connect, I CANNOT "forget" my home network; no matter what I do. That's seems a bit strange.
Hope this helps someone else. Am not working right now so really need this to be working as part of my job search. :-)
Community groups are GREAT !!!
Beside reseting everytime the devide, it worked for me (I think that it's the same as reseting the router each 30 seconds):
Inside the router configuration (e.g., accessing the IP 192.168.0.1), change the "Group key update" value from 0 to 30 seconds, under the "Wireless > Security" configuration, right below the WPA-PSK/WPA2-PSK item.
Router: TP-LINK TL-WR740N / TL-WR740ND.
I have a number of WiFi connections saved in my phone (including two different ones in my house) and sometimes even my own WiFi won't connect. I can see it fine and the status will change to "saved, secured" but it wont actually connect no matter how many times I click on it. This doesn't just happen with my WiFi, sometimes it will happen at work as well and since I'm the firewall admin I know there hasn't been a change to the AP settings. In fact I know there hasn't been a change to any of these devices and what's really strange is that without any changes it will start working again at some point. This happened with both my S4 and my Note 3 but never happened with my S3 (all the same WiFi networks). My buddy has iPhone 4 on the same networks at the same time and never has an issue.
Anyone else having this problem?
I've seen this with:
Fortigate AP's
Sonicwall AP's
Comcast home routers
Frontier home routers
I have same problem in my iball router. I am using Note3. Last night I was surfing n my wifi disconnected n showing saved secure...I don't know why this happening. Is it someone hacking my wifi router ?
First turn on Wi-Fi on your Android device
Go to system Settings >> Network >> Tap on WiFi
Now you will see various Wi-Fi networks
Long Press on your Wi-Fi connection
Now you will get two options in the pop up- “Forget network” and “Modify network”.
Choose “Modify network”.
Enable- “Show advanced options” .
Change IP Settings (which is DHCP by default),to “Static”.
Now you should see a bunch of advanced options.
Simply assign a new IP address. For example if it was 192.168.1.3 you can change it to 195.168.1.253. Now “Save”
The above solution is for devices running Android Jelly Bean 4.2.x, 4.3, Android 4.4 KitKat and Android 5 Lollipop. It may also work for Android 6.0 Marshmallow devices.First turn on Wi-Fi on your Android device
i have the same issue with my Samsung Galaxy Ace 2
"saved, secured" but no internet access
i've tried the WPS thing but it didn't work
i've tried changing the connection to static and it didn't work either
please help
I am having a similar problem. Something changed or broke and I am no longer able to access wifi. I even went so far as to configure a new connection on the modem as well as on the android mobile phone (LG Joy). This malfunction persists. I am leaning towards blaming the hardware.
*** LG Joy settings
Password = [as specified in modem wireless settings]
Proxy settings = None
IP settings = Static
IP address = [as specified in modem setup settings]
Gateway = [as specified in modem setup settings]
Network prefix length = 24 [255:255:255:0]
DNS 1 = [as specified in modem setup settings]
DNS 2 = [as specified in modem setup settings]
*** LG Joy info
Status = Connected
Signal strength = Excellent
Link speed = 65Mbps [presumed to be 65000000 bps]
Security = WPA2 PSK
The "only when plugged in" did not work for me.
Multiple resets did not work for me.
Lifesaver thanks, using the "same as ip router address in DNS1 made all the difference
(as opposed to the dns1 number specified when logging into router info) ... thanks again! :eek: :D :D
Samsung galaxy 4A
I have this issue on occasion at school (and since I am a student, I do not have any sort of access to the networking devices).
Every once in a while it'll work to simply forget the network, then reenter the credentials and log in, but typically I have to restart my device.
If it matters, I'm currently on a Google Nexus 5, so that might have something to do with the issue since the phone is 3 yrs. old. I just bought a Pixel XL, so hopefully I won't have any issues with that once it arrives.
I had this problem, with the public WiFi at the hospital for special surgery in Manhattan, on my Android phone, a Samsung galaxy note 4.
I fixed it, after reading through a few forum threads, by finding out the IP address of the router and a device logged into the network (from a friend whose phone was working fine with the Wifi) and then checking "static" under the advanced network options in the Wifi settings. I entered the address of the router under "gateway" and an address similar to the device address of my friend's phone, but one digit greater (in the last set of digits, like if his was 192.168.1.147, I made mine 192.168.1.148). Then I connected and it worked fine.
The problem appears to be with the DHCP client in the phone's Android OS - which is the latest version Verizon has given us ( 6.0.1) ... and no, checking "use legacy DHCP client" in developer settings did not fix it. Obviously I couldn't try resetting the router as this would kick hundreds of people off, at a hospital no less! Plus, everyone with iPhones and laptops was having no trouble connecting.
Hope this helps.
I found this thread because of the same issue. In my case it suddenly started after placing the Waze widget (not the app) on one of my screen pages then moving it to the Trash Bin after it kept crashing. I went through and reset all my apps' permission settings but to no avail. Finally, I put the widget back up and everything is fine. I have to do a little research to verify it and see if I can remove it again without causing the issue again, but at least I'm not gobbling up my data plan.
PS: I'm using an AT&T Glaxy Note 3 running KK 4.4.2.
Only having this problem with my lg stylo and twc modem. Reset phone still not working.
Solution!!
I just had this issue this morning randomly. Both of the galaxy 5s phones didn't have wifi, both stated "saved, secured" and would not connect no matter how many restarts or forget network reconnect to network attempts were made.
On my network I have MAC address filtering enabled to deny access to 1 address so that it will be forced to connect to a network range extender.
The settings in the router were properly set but still I gave it a try and disabled MAC address filtering. Almost immediately I had connection again to wifi on my s5. I thought it strange so I reenabled the MAC address filter on my router, the wifi connection remained connected. I then disabled wifi on my phone and reenabled wifi, this was just to test that it would come back and it did without issues. So there was some glitch through the router that even power cycling was not able to correct.
Router is a TP-Link WR841N
Same issue "saved, secured" with an Xperia Z on my home network router.
What always worked was switching to flight mode and back again - then it reconnected after about 30s by itself.
I tried disabeling the mobile data connection only, that didn't help. But since i disabled bluetooth reconnect works every time.
Pls. guys test this in your casses and give some feedback.
This suggestion of switching on airplane mode, then wi-fi, then turning off airplane mode and - win!!
This phone has only been doing this for the last couple of days - no idea why!
Thanks!
I experienced this problem on my Galaxy S5 today for the first time and I tried various suggested Solutions, none of which worked for me. What did work for me was downloading an app called wifi analyzer at the Play Store and as soon as I turned this app on it showed that I was connected to my home network which before had only been showing saved, secured and would start to connect but then immediately quit. So when this app showed that I was connected I went back and checked and sure enough it had connected. The connection remain stable even with the app turned off and I could turn the WiFi on and off and still connect immediately. I had another analyzer app that I had used previously to test both my Wi-Fi and my mobile carrier which did not have the same effect when I turned it on.
cate006
