Wifi Problem after ICS
seabromd
Hey all,
I updated my 7.7 (P6800) to 4.0.4 using the Odin method. It all went great and seems to run well, but after about 1/2 an hour it stopped connecting to the Wifi internet, and won't connect anymore.
It finds the internet, it lets me enter the password, but then it doesn't do anything.
Any suggestions?
I had the same issues yesterday but that was before I updated using Kies and I ended up doing a factory reset to fix it. Not sure if that would work for you since my issue happened before the update. Have you tried different networks? And I'm assuming you cycled power.
Spontaneously it started working again, though it occasionally screws up and a restart seems to get it going again...
I might just leave well enough alone and see how that goes.
Glad to hear it's working again going through a full wipe takes a lot of setting up time after.
blåhaj
