Will AT&T charge for Tethering & Portable Hotspot?
Alvin Tran
Active member
Feb 16, 2013
28
I want to know if AT&T will start charging for the stock Wifi Hotspot feature in Android or will they just charge the data usage?
Actually they can and will move you to the tethering data plan if they notice you tethering. I believe it is $50 for 5gb? Not really sure since I have the old unlimited and don't really keep up with it.
Is that what you are asking or is that what you want?
Sent from my SAMSUNG-SGH-I317
I think this is correct. I think $25 for the cheapest unlimited calling and then you add the 5gb minimum data which includes tethering. So maybe $75 is the cheapest?
I use it on the GN and N4 and they have not notified me of it. Maybe because I don't abuse it or maybe because I am out of contract and would just leave.
Yes if you abuse it they may make you switch but normally they wont because they have no way to tell aside from your data usage.
Sent from my SCH-I605 using Tapatalk 2
FCC Forces Verizon to Unblock Tethering Apps and Pay a $1.25 Million Fee - TheUnlockrTheUnlockr
At the bottom...
"In addition, the company recently revised its service offerings such that consumers on usage-based pricing plans may tether, using any application, without paying an additional fee."
I hate the phone companies. They knew they were breaking the law.
Although that only applied to Verizon and that particular Spectrum, which they agreed to. The other leases from the other Carriers never had that in their conditions. Unfortunately....
But just maybe it fired a warning shot.
Att will not penalize you nor can they block you for using the feature especially if you are on a tiered plan. Dont forget att makes more money when you use more data. Just use your tether as youd like and dont abuse it and you will be ok.
04ijordan
