Will We See Gingerbread?
I think we will see it for the Fascinate after today's announcement. I will be looking forward to what the devs here do with it, should be great if the Community ROM is any indication. :D
Yeah, I cannot wait to see what the Community will do with GB for the Fascinate!
First thing we will probably see might be the best - completed CM7 roms
Sent from the shark tank using Tapatalk
I think I received Gingerbread, but my phone was rooted.
Overnight my phone got bricked, which I can assume came from an attempted Gingerbread update. I got my phone launch day so I figured I'd be one of the first to get it. I tried flashing CWM with no luck so I went ahead and flashed DI01package3.tar.tar which I believe unrooted it. I tried downloading ROM Manager and Root Explorer and neither seemed to work. I went then to About Phone to check for a new update and nothing showed up. It said Please Wait... for awhile, but then nothing happened. Will the update just try again by itself? Or do I need to keep "checking new" manually for it to show up?
Edit: When I go to status it says Server Unavailable, code 500. What does that mean? (I'm connected to Wifi)
You have to turn off WiFi as it only updates via OTA.
There isn't a GB update going out yet, and probably won't be for months, but if you hadn't updated to 2.2 yet, that is most likey what it was
Bitterbuthappy
