[WIP][ROM][2.3.7]LeWa Madness Alpha3
Re: [WIP][ROM][2.3.7]LeWa Madness Alpha1
Flashed back 2 ics just to thank u awesome rom wonder wat new features will be included in next alpha
Sent from my LG-LS670 using Tapatalk
Most probably fixing bugs, updating when LeWa source gets updated, Kraven's CM7 updates if any.
I might try porting it to Kraven's ICS, but not sure if it's going to work. Not much at the moment. Got a lot off school assignments pending
I thought I would put my two cents in. Just flashed the ROM and so far I am really digging it. Great Work! It seems very smooth and polished so far, especially for an Alpha Build. Is there no Email Client that comes with this gapps, or am I just not seeing it? Anyway, thanks for all your hard work and I look forward to future builds.
Good job! But your advice was enough contribution by itself. Glad to see others keeping the optimus machine rolling.
Sent from my PG86100
There must be one :-\ Not sure how it got missed. I'll upload another version by midnight or early tomorrow morning. Including email and gallery.
I have no idea what that meant :-\. Thanks much though.
Great job man, hopefully when I have more time I'll be able to try it out, but it looks really awesome. It's nice seeing the boards come alive lately :P
Holy crap this thing fliessss. Quickpic works great instead of gallery and ALL features are working fantastic. WTG with this Rom. Beautiful.
Updated OP with a link to themes. Let me know if they work.
You can always check with one or two to see if they work and then decide which one you want. :D
I am a big fan of this ROM. Fantastic work! I highly recommend this. Very easy to use and lots of cool features.
Is anyone else noticing this ROM is draining the battery? I went from 100% to 70% in like 90 minutes with wifi off an my phone basically asleep the whole time. Any tips for extending battery life? I have setCPU to underclock my processor with the screen off and I know wifi can drain the battery, so I have that off when not in use. I really like this ROM but the battery drain may be a deal breaker for me. Anybody else noticing a similar issue or is it just me?
Truth be told, wifi actually saves battery, unless you have it on with no wifi signals present (constantly searching for a wifi signal drains bad!). Usually it is one of the radios that causes battery drain, either phone or data.
The themes work, as long as you extract the individual files to the root of the sd. You can't just leave them in a folder. It makes my sd card look like a mess, but when you press import in the theme app it will add them to the lewa theme folder. Then you can delete them from the root to clean it up after. There are a few Themes that are making the app crash. So you will have to import one by one. It's a pain in the butt, but you have themes, and pretty good themes at that.
I have my phone overclocked with wifi on, while I'm in wifi zones, and I've been running hard since 7:00 est this morning and am now down to 93%. Not too bad. I've seen worse. Aesthetically this ROM is one of the best, but some really awesome features.
This is definitely my new daily driver. No crashes. Smooth scrolling. Data is fast.
Anyone else having issues getting the MiLocker theme to stick after reboot??
EDIT: nvm, it just takes a few to revert to the themed screen
Does MMS work? Having issues...
I just downloaded everything this morning and put it on my phone, and flashed everything...
Market wouldn't download any apps, it would say "failed to download" or just a continuous "downloading..." but flashing the gapps from Kraven's thread fixed it.
I got a small MMS file today from a friend, but it wouldn't download...haven't tried sending anything yet.
It would be nice if I could get rid of the "data usage" thing on the top of the Notification list...Sprint has unlimited data! :)
Battery life is about the same as CM, not bad!
Also I was noticed, under the Power Manager app, I noticed "FeelBack" at the bottom...not sure what this is, but turning it off seems to tell me it saves a lot of battery than with it on lol.
Overall this is a pretty sweet ROM :cool:
Might have missed the answer to this, but, are anyone elses physical buttons (home, menu, back, search) staying lit up? Even after the phone locks itself?
EDIT: Changed the FeelBack option to off and they went off.
EDITEDIT: I'm LOVIN this theme! Great work! Haven't ran into any bugs, yet. Only had it flashed for about an hour though, so I haven't got to play with it much.
Sudansh, my battery life seems to be pretty good. If you use wifi a lot, make sure to under wifi settings, press menu button, go to advanced and turn off wifi notification. Else radio will be constantly searching for wifi signals. :)
And, I added email to the ROM now, if you really want it.
Reactions: sundash22
Arwen
