[WIP][ROM][2.3.7]LeWa Madness Alpha3
Re: [WIP][ROM][2.3.7]LeWa Madness Alpha1
Stable. That is how I describe it. It may not be pretty in some aspects but dude, all I've gotta say is, you're keeping me from cm9 and I was pretty excited for that. And I love your MIUI port, can't wait 'till its fully stable. Love your work man, if you want any help hit me up :D
First of all, thanks much for the kind words :) . I owe all the thanks/likes I get to the devs here at optimus S and gannon. Hopefully I'll get to learn more from Kraven, Drew, me2151, epidenimus, others in the near future ;)
And, I didn't do the MIUI port :D me2151 and gannon did it :) Thanks to them.
Reactions: rukin5197 and Alvis
Is there anywhere I can get the vm app? This recueving a text message when I have a new vm is a little obnoxious
Let me actually test Kraven's gapps with Vmfix and I'll hook that up to the main thread instead.
But yeah, you can try it out and let me know if it works.
would I just flash his zip file?
EDIT: I just seen the post a few up saying to just flash it lol. I'll try it now, and let ya'll know how it works.
EDIT2: It works, still getting the text message too though....weird.
Gonna try a fresh flash of the ROM with the gapps w/ vvm and see what that does.
Wasn't there a fix for that issue in CM7 thread? I remember at the back of my head seeing it. Must be buried in there somewhere
Found it but haven't tested myself. Let me know if it solves the issue.
http://forums.androidcentral.com/lg...kraven-2-7-2012-zvd-only-172.html#post1569099
Post # 1712. I need some sleep now :(
I wiped everthing and re-flashed Rom and the gapps w/ vvm fix, just waiting on a voicemail hahahaha
Yes, I was receiving double texts, the other way around this is to just turn off notifications to the messaging app you don't want to use. Or unzip the gapps from CM7 and take out the messaging.apk rezip, flash in recovery and it's done.
Question-
Yesterday I was trying to change the battery because I just don't really like the blue, so I edited the framework-res.apk to add in the battery .png's from YourMomROM and then repackaged it and tried to flash and it didn't flash right, I'm thinking I did something wrong. I didn't try to load the ROM because it didn't flash like it should have. I didn't want to brick the device so I went back to the original flash of LeWa Madness. I'm pretty sure I'm missing a step maybe you can help?
Question-
I'm not a pro at this yet but let me try. How did you change the icon? Did you unzip the apk? Doing so will void the signature. Easiest way is to use 7zip, open the archive, replace the icons but make sure the name is same, click back and it will ask you to save changes to archive, Save it and push the apk to you phone or the ROM zip and flash it.
You may find that MMS no longer works if you remove the stock Messaging app. I'm sure there is some string to enter in and get this functionality with a third party app, like GoSMS, but I have not found it yet. Let me know if you do.
No, but we're getting double posts...
Get it?
No?
I had double texts but I rebooted into recovery and factory reset and it worked.... Try that ;)
Lmao yeah I got it. I wiped everything and reflashed, its fine now.
I love the file manager :D
is there some sort of menu i can acces for tablet tweaks?
(specifically disable lock screen)
Man, just flashed this Rom and kinda got stuff set up. It's actually my favorite yet. The data is blazing, cool theme installer. WOW. Keep this going please! Great potential
Thanks, there might be an update soon. Gotta check with gannon. :)
Hey, does anyone see duplicate contacts or is it just me? (God, I mess things up fast, any fix for this?)
Nope. I flashed the ROM last night, no double contacts for me....? I have had that issue after a fresh install before however. It seemed Google somehow double saved my contacts. Had to physically erase them.
alexajamez
