[WIP][ROM][2.3.7]LeWa Madness Alpha3
Re: [WIP][ROM][2.3.7]LeWa Madness Alpha1
Just flashed this and I must say it is probably my favorite by far. Snappier then HydroRom and I think ZVD is the best radio for my device as well. Just a quick observation / question...
I noted the bug about not being able to install some non market apps... Flash appears to be one of them. Any way around this?
how exactly does this compare to the other zvd roms?
does it auto update?
Yeah, non-market apps have some issue. Observed it with tapatalk. NO workaround yet.
There are still a few bugs but it's a decently smooth ROM. CM7 is still my fav though :p
Flash it and check, if you don't like, you could always nand restore :)
One other bug I noticed is that the MIUI lock screen does not stick after a reboot. Anyone else notice this?
OK, I got SOME of my non-market apps to install via Titanium Backup (must..... have..... pron!!!!!). Flash 10.2 seems to just spin it's wheels when I try to restore it.
I couldn't get Market to work until I installed thekravens gapps-gb-20111214-237-signed.zip
I had to reboot 2 times after initial install to get my gmail account to stick. I kept getting market errors after that concerning me not being logged in, but a manual FC and restart of market fixes that. Haven't had the problem after the 5th or 6th reboot.
Market closes after I choose to dl something, but it continues to dl and install the app.
I was able to get Swype to work thru tits-bu...
I don't know if I can't send text or if my wife is just not rec'v them... OK, texting works...
I use my phone as a gps during my work day (I'm an in-home service tech), so I'll test out the gps when I go to work on Wednesday.
Otherwise, damned nice job!!!
MiLocker is an app, and doesn't load until the os is loaded. The stock lockscreen will be what you see at boot, but MiLocker takes over after the initial unlock.
Or, it should... It's how it's working on my phone atm.
So the DL Link is for the newer build? Can I just dirty flash to update or should I flash the dubug format.zip and wipe caches.
Frankly speaking I never ever dirty flashed my device until now. Even with CM7. But technically you can just wipe cache and flash it. Make a backup anyway :p
First off, thanks much for the feedback. So, did you have issues even after installing Kraven's gapps?
I didn't have any issues with mine apart from inability to install tapatalk (non-market). I could install root explorer just fine.
Still, if there are no issues using Kraven's CM7 market, I could just link to that. Let me know.
Mine does not stick either.
You could try this, push MiLocker.apk to system/app and set permission as other system apps. Reboot.
I'm stil not sure if the "You Are Not Logged In" messages I was first getting were a Market or OS issue, but they went away if I force closed then reopened Market. I do a lot of rebooting when I install a new rom, and the message stopped coming after the 5th or 6th reboot (and opening Market, it was a Market message).
The market you linked never worked for me. It would FC almost immediately.
On a side note, I'm getting ready to flash a notification bar theme I just cooked up in the UOT Kitchen.... Wish me luck...
EDIT: No joy, it won't let me change the battery. I got the rest of the notification icons, and the status bar icons to change, tho....
Never worked sounds weird :/ and yeah all the best for notification bar thing :)
Link it up with a screenie if it works ;) (although I doubt it, since the framework is made of 2 files instead of one. there is an extra .odex file with normal .apk and it wont let you theme framework-res.apk alone. but yeah, yo never know)
The gapps never worked for me either, market worked but nothing would download so I used Kraven's gapps and everything is working perfect for me.
There we go. Everything but the battery.
Is that spb shell or Regina, nice icons btw :). did u like this battery or kitchen couldn't theme it?
That's weird. It worked for me always. Should I just remove the link and hoot it up to CM7 gapps?
Which one are you guys using? Old faster market or new one?
Dunno... :confused:
I'll try again later. Meanwhile, I must go to the in-laws for the race. I'll be back later today. Even tho I hit the thanks and like buttons, I want to say Thank you!!
Beanz2003
