[WIP][ROM] CyanogenMod 9 for LG Optimus S (Yes, it's ICS!)
Status
Not open for further replies.
Great! Which version of gAPPs and do you have a link?
I used CM9 GApps v11 for ICS ... flashed that after a clean ROM flash... Market didn't pull over so I extracted the archive, copied Vending.apk to /system/apps (Changed permissions to Owner r/w) using root explorer and restarted. Maps, voice, music, voice, sync works fine. YouTube does not.
OH. MY. GOD. I was just googling around to see if anyone actually attempted to port ICS to the Optimus just for s and giggles...and here I am.
Looks like a lot is not working but hey...I'm amazed someone even bothered! Tip of my hat.
the main thing that isnt working is data and camera...
I have ICS running on my Optimus 2X. I have flashed the Gapps in the recovery-menu. This ROM works great. Including texting and the homebutton. Only the camera is buggy, but that is not a disaster. it is now my daily ROM. Thank you!
You flashed this ROM onto your Optimus 2x?
Any chance there's a way to remove startup permissions from
USB mode? It pops up all the time, even at boot. I'm quite capable of starting this app at my own leisure as needed.
First day with this ROM has went fairly well. Biggest problems I see at the moment are lack of hardware acceleration... a few things are somewhat laggy and you can see some areas where graphic performance is lax. If this is indeed due to lack of hardware acceleration, then I can not wait until its fixed. I'll be running this as my daily,so if any devs need crash reports, etc.let me know what I can do to help! Can't wait to see what this can turn into! Big thanks to Drew (I've circled you under my Google circle) I never thought I would see ICS on this phone!
I love the looks of this ROM. very clean and I love it. I do not have a mobile network available though and wireless won't seem to turn on. I am ok with some of the other bugs but I need calling. any help out there?
Sounds like a radio mismatch. Update to zvh baseband. Just know data does not work.
remember, this is not even a beta. it's a development and testing ROM right now. No data, no official market, no texting.
All things are being worked on to make this a working ROM but it will take time.....
I am aware of that and ok with that but the ROM documentation claims that phone calls work (incoming and outgoing) and wifi is enabled. I have the correct baseband and I made sure to make the changes in the recovery mode before I flashed. just wondering if anyone has the same issue or if there is something that I missed in the ICS settings.
Drew. Lupohirp just update with dull hw acceleration
Sent from my Amazon Kindle Fire using Tapatalk
Ok.
Phone and Texting:
Code:
Download Kravens cm7.2 FULL IHO
Download Drews Optimus S CM9 port
Move both to sdcard
boot into recovery
wipe data(cache dalvik cache too)
Install Kravens 7.2(yes it is a baseband mismatch...)
reboot into the rom(must load stuff into cache)
after rom fully boots power off and power into recovery
flash Drews CM9 port( DO NOT WIPE DATA OR CACHES!!!)
From that to fix the home key issue(must use adb):
Two ways:
Code:
adb pull /system/usr/keylayout/Generic.kl
edit key 102 to say HOME                               WAKE
adb push Generic.kl /system/usr/keylayout/Generic.kl
Code:
Download my premade Generic.kl from http://www.mediafire.com/?d2gmfck4cmg3bd7
Navigate your command prompt to where you downloaded it to by using cd command
Time for market:
First. delete some System apps you dont need(i deleted calender calender storage live wallpapers and Voice dialer( you need to delete up to 6 mb.)
Extract Vending.apk from the 20120131 gapps.
open up a command prompt(im on Ubuntu so i use Terminal)
navigate to where you put Vending.apk(in the terminal using the cd command)
Type
Code:
adb remount rw
adb push Vending.apk /system/app/Vending.apk
adb shell
adb chmod 644 /system/app/Vending.apk
exit
adb remount ro
Thats my progress so far.
For you people asking about the google apps and such, here is what has been done so far. Once again, having this referenced would be helpful so people don't keep asking so many repetitive questions.
Just for clarification: This is TEMPORARY. No a permanent fix, but one that will work for now if you want ICS and are impatient.
:-D
Status
Buddylyon
