Wireless Tether 4 Root on Fascinate
Wireless tether pre9 and pre12 confirmed working with win7 64 bit, usb and bluetooth.
Confirmed does not work with wifi, but why would you need to wouldn't you just run your laptop off the wifi?
I am running windows Vista and the computer wont connect to my phone. Driver and USB seems fine. It recognizes the conection but will not conect. it gets stuck saying "connecting to wireless android network" any fixes you guys recommend?
Can anyone else cofirm wireless tether doesnt work on windows 7 64bit.?
Which wired tether app are you using, Ki?
downloaded the latest wireless tether in the market and i am running windows 7 64 bit and was able to connect with my fascinate, wireless tether version is 2.0.5 - pre9
I tried pre 9, 11 and 12 which is the latest but did not work at all.
you are the first I heard working on Win 7 64 bit. you are very lucky.
Then, maybe Intel wireless 6200 problem?
Anyway, I am happy with the speed of wired tether program.
I have also used pre 9 and pre 12 with a Win 7 64 bit and Linux system with no issues on both usb and bluetooth.
In any case, you have a program that works for you and that is all that matters.
Download it on your computer, mount your phone, copy to SD card, navigate to it with your phones file explorer of choice, you'll have an option to install it when you select it. Once you've installed it you can remove the file from your SD card if you wish since it installs in your system/app folder. Works for all .apk files on the phone.
This is the newest one:
wireless_tether_2_0_5-pre14.apk
Have not tried pre13 but have done 9/11/12. Barnacle has been more reliable for me.
Both worth trying.
BeshevGames
