Worst battery ever
Sometimes you need to go to task manager and stop other programs from running. I did find that to be the reason for my quick power loss.
Managed to get that before it shut itself off. 6 hours of on screen time on the first charge cycle. That's almost in the Note 2 territory.
Sent from my Samsung Galaxy S4
Wow, you got twice the life I did. Doesn't mine seem bad? My iPhone 5 blew this out of the water.
That looks pretty unusual.
Sent from my pure Google Nexus 4 using Android Central Forums
I have pretty poor reception at work, like 1or2 bars. But still, same reception on my iphone. I hope this improves because that's pretty awful.
There should be a rule where if you are speaking regarding your battery, you need to show proof (screenshot) too many trolls these days.
Anyone have any idea what's killing my battery so fast? Phone gets really hot too.
Sent from my Galaxy S3 Life Companion
It's your data. That burns way more than when on wifi especially LTE. Toggle your data off with a widget like widgetsoid or power toggles. It's fast and saves lots of battery.
I use my droid all day and for the most part i have to be plugged in because by the second my battery is at one bar. I just bought this phone. It is fast, even on the battery.
Which phone do you have
Sent from my SGH-T999 using Tapatalk 2
Sent from my Galaxy S4 White - using Tapatalk
Try this:
Power off phone, remove battery for 2 minutes, then put it back in.
I have no idea why but this would fix random run away processes that killed my galaxy s3 battery exactly like what's happening to you.
I'm getting about 12 hours usage screen using 71% total time screen on 4:40 hours
Were you using the maps that much? On my first cycle of the battery I noticed google maps used around 30-40% battery and I didnt even use maps, Found out the latest updates of maps was causing this, uninstalled the update and battery life was a lot better...
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Without knowing the screen on time, I don't think those screenshots are too informative.
Nope. I'm not sure what maps was doing.
Whatever it is doing it is eating your battery! Does the S4 Have a task manager like other Galaxy Phones? On my Note 2 I will periodically close all running apps and clear the RAM just incase there is a rouge app.
It's Google Now. Sucks life out of your phone and uses location services/maps.
I am highly impressed with the battery life on my s4
Sent from my SPH-L720 using Android Central Forums
I'm happy with life of my battery so far.
Lassi876
