Xoom possible defect
Does anyone's glass look kind of wavy at the top if you look at it from the side?
Ok update.. Just got my exchange unit in the mail from Motorola seems like a new one. Bummers, it has the same issue just less noticeable. In this case its right over the camera area.. but im a happy camper since its really barely noticeable even when viewing in the prior angle.
Has it gotten any worse for people out there with the glass coming undone?
Mine is the same - about 1 sheet of paper thickness is protruding at the top, hasn't changed at all since my last post.
(I've had to switch to 1,500 lb paper though)
(j/k)
This happened with my first Droid 2 aswell... The glass came off of the top right corner just a little bit. I think it is a design thing though, to make replacing parts easier. Only had my xoom for an hour, hope mine doesn't get this...
I got the wifi version and I am seeing this too. It's very very minor. I will keep my eye on it
holey crap i just looked at mine and its doing the same thing :( back to staples i go....
Nope, nothing on mine.... crap luck I guess, usually when they ship a single batch, if one of the units they have in the batch has an issue, the rest probably have the same issue. Its all the luck of the factory draw
I keep checking mine, I don't have it so I guess I got lucky. Did this happen out of the box all the or were some over time?
Mine has been like this since I got it. I didn't notice it until I read the OP. its really so minor, it doesn't look like a flaw it looks like it was designed this way and it hasn't gotten any worse so I'm not concerned.
koltyn
