- Apr 22, 2010
- 17
- 2
- 0
Hey Guys,
I was wondering if anyone who has the Invisible Shield HD installed is having the same issues as me. I had mine installed at best buy and the rep did it perfectly to where all the seems matched up, so I really had no complaints at the moment.
Upon using my phone after it was installed though I realized the proximity sensor wasn't functioning at all anymore, and when I looked at how the screen protector was set up, there is a notch for one light (which isn't listed in the user guide) but right next to it is where the proximity sensor is and it's completely covered by the screen protector.
So I was wondering if anyone else had this same issue and if they've been able to fix it by a means other than taking a razor blade to my phone...
