Zenfone 3 Max
A
AC Question
I have tried every conceivable way to assign a specific ringtone to individual contacts tto this phone. I am running Android 6.0 OS (mARSHMALLOW) Have contacted ASUS who says it can't be done. Also extremely difficult to type a text. Spacing isn't good. Third party apps no good. HELP !!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,871
5,135
113
Welcome to Android Central! In the Contacts app, if you select a contact, then tap the overflow menu at the upper right, is there a Set Ringtone option? Is that what you're using, and it still doesn't work?
Are you trying to select a preinstalled ringtone or a custom one? If it's custom, where is the sound file saved -- to Internal Storage or the SD card?
