cant get past the activation page. it tells me its unable to activate my mobile data service. any idea whats causing this?
With these ICS ROMs, the mobile data needs to be turned on manually. Go into settings and turn it on. If this doesn't fix it, reboot the phone and try again. If that doesn't work, or you've already done all of this, let me know.
actually i dont believe the speed test im using. surfing the web using web data seems fine.
What are you using to test the speeds?
I love this rom but how do I get my contacts back without verizon backup assistant app? Is there a way to download this application? The contacts on this rom only list my facebook contacts but not the ones saved through my backup asistant before I installed this.
Do i need to install an updated radio when running this ROM if i am coming from GB?
I'm having a couple of slightly annoying random issues as well; both the Gmail app and the stock email app (which I use for my school email) seem to stop showing me the content of messages after awhile. I can see it as a preview, but when I open the message itself, it's blank.
