I have a 2010 Civic with a USB aux in and the only way I can get the Charge to work with my stereo is plug it in and then turn the stereo on/off. Then it just treats the charge like a mp3 CD. Seems like each artist has their separate folder. I use iSyncr to sync so not sure if that is an issue.
Anyone have this problem and have found a solution?
Thanks.
Major thing I do want is have playlists.
Thanks.
