It sounds pretty odd, but how to change the default alarm sound?, I checked all the menus and did not find a proper tab
The alarm sounds are set individually with each alarm. Open up the screen where you can set alarms, then look below "Description" and it says "Alarm Sound."
So, in steps, that's:
Clock>Slide bar at bottom to Alarms>Add alarm>Alarm sound.
it's very simple
first download "Es file Explorer file manager" application from play store
then go to the location where song is saved
like in my case I want to set a whatsapp audio that my friend send me as an alarm...
so I went to file manager then whatsapp folder then whatsapp audio folder and I clicked on the audio it gave option to open in which application such as Google play music and es media player
click on es media player then there's a three vertical dots at top right click on that and set Ringtone then set as alarm click on it.... That's done now your song will be available but you have to select it
go to clock
click on sound and your song will be available click on that....
ENJOYYYYYY
it's very simple
go to clock
ENJOYYYYYY
