I recorded a short video today with the record with audio option enabled, and there is no sound. Any suggestions will be appreciated.
I think the problem is most likely an operator malfunction.
I got caught on this myself.
I went thru the whole press the speaker / erase the cache partition / factory reset
bit and none of it worked.
Android is a new thing and the applications I have seen are not polished yet.
(Example: having to use the Gallery to select a contact photo.)
This assumes the Galaxy S8 but should be similar on other Android cellphones.
I am going to type this as if you want to play back a video you shot (with sound).
Tap 'Gallery' then 'Camera'.
You will see thumbnails of the videos you have taken.
Tap a video thumbnail.
The video will appear to be playing in a loop without audio.
There will be a 'play' icon in the middle of the video.
Tap the 'Play' icon in the middle of the screen before it disappears.
The video will start playing with audio.
Note:
Make sure you do not have your sound turned all the way off.
