It should pull from the browser. To switch go to Manage Applications, click on whatever Home launcher you are CURRENTLY using, and check "clear defaults". when you press the home key it will ask which to use.
Also, you can make the people widget pick from any pre-made group in your people/contacts. You edit the actual members of the group in your phone book and then hit the sync on the widget.
