Im in need of some serious help. I downloaded CWM red, and everything seemed to be going fine. I found the blackhole ROM when i went under sd/ and i went through all the other files until blackhole came up right where you said it would. I hit install and toggled down to yes, it then said it was installing and then it said install complete at the bottom, however the red CWM menu was still at the top. The only way i could find to get out of it was to click sd card update.zip, which i did, then it went and gave me the option to reboot which i did. Now when my phone turns on, the unlock screen works but when i unlock there is only a black screen, the notification menu is at the top which shows my 3g and the time and all of that, however my sd card does not get scanned. I can press the power button which gives me a bunch of options including download, reboot, recovery, power off etc...however i cannot do anything else on this black screen. What should i do????
