kms108
Re: [GUIDE] Galaxy Nexus MOD for Palm Touchstone without solderin
I think anything that is thin and stong to replace the guitar pick, I think a credit card may work or those phone opening tools.
Ok, just trying to get all the pieces together for this...
Touchstone dock, check.
Touchstone internals (specifically from the Pre not the Pixi), check.
Copper tape - would this do?
Rare earth magnets - these are a wee bit bigger at 8mmx1mm than the 1/4"x1/32" you used but they should be ok, right?
edit: knew I'd forget about something... the guitar picks.
I've never played guitar so I don't have any kicking round, when looking into them it seems there are various different thicknesses, any particular one I should go for? Would thinnest be best to avoid damaging the handset or would that just make them liable to snap?
Also, trying to keep it all as low-profile as I can in the battery cover, would superglue be ok for holding stuff in place?
It should be fine for the magnets at least, what about the coils?
Thanks.
