I got a Note 3 on Father's day and everything worked great. Last night I went to change the battery and when I turned it on, both the wifi and Bluetooth sliders (in settings) were off. If I try to turn either on, they go dark grey and won't turn on.
Here's what I've already done:
-Powered off and restarted
-Hard reset (taking the battery out)
-Factory reset
I did eventually turn it off, took the battery out and pressed on the back with some force and when I turned it back on, the wifi came back on but when I looked in the morning, it was back to being stuck off. What do I need to do? Any advice is appreciated.
-I bought the phone used so there is no warranty, for what it's worth.
-Factory reset
