The 3G problems on my Optimus V spurred me to write this network monitoring utility; I've named it Connection Checker. Beta testers and feedback are both appreciated.
Essentially it is a service that runs in the background and actively monitors your network connection. If it detects that your Wifi connection isn't working, it'll turn off Wifi and fall back to mobile connectivity (Wifi is re-enabled after some time). If your mobile connection can't pass data, you get a notification and airplane mode is toggled.
For the last two weeks I've been running this and had no ill effects on my battery, and have had vastly improved network connectivity. The UI is still a work in progress, but it is getting close.
Things to note:
* The log doesn't automatically refresh
* Does not start on boot
* The icons are microphones!
By downloading this software you understand this is experimental software. As the author, I am not liable for any problems resulting from the software's use on your device.
Initial beta release v1.0.1
http://dl.dropbox.com/u/5477013/ConnectionChecker-1.0.1.apk
Changelog for v1.0.2
http://dl.dropbox.com/u/5477013/ConnectionChecker-1.0.2.apk
* Tested on Android 2.1, and it is now installable there
* Fixed tab icons
* Log screen now updates when an event happens
* Added status of service to log page
* Added more events to the log, and removed toasts
* Made notifications clear on click and open the log
* Moved "start on app launch" option to Advanced
* Added "start on boot" option to start app when booting device
* Several bugfixes and improvements that are not visible to the user
The public release is now at v1.0.8
Market link for the free version:
Follow this App in the new thread.
Things to note:
* Fixed tab icons
