A
AC Question
Can't connect to WiFi
I cannot connect to wifi. All of a sudden my wifi stopped working. I even did a factory reset on it and nothing. There is no wifi addresses showing to try to connect to. When you try and turn it on the button slides over to on but its grayed out and in the middle of the screen it says turning on and that's all it does. I have had no prior issues with wifi. It's always worked fine.
