Does anyone here know how to fix this problem? Everytime I say hi to someone it gets changed to "to", and everytime I type "id" it gets changed to "is". Surely there's a way to fix this problem without having to completely disable spell check?
Which keyboard are you using?
Turning the phone would help increase the accuracy, but means I lose one handed texting. Manually adding them to the dictionary doesn't change anything because I believe they're already in Android's stock dictionary. Blah.
Once you add words to the dictionary, they will be available when you go back to portrait mode. Landscape mode would just give you the option to work with the dictionary a little more.
Sorry TM Xopher clarified what I was saying, I do this and when I return to portrait mode I never have a problem
