DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 10 of 10
    Question International Usage of EVO LTE
    What countries will the EVO 4g LTE work? I'm traveling to Japan, Hong Kong and China soon and I'm just wondering.
  2. #2
    Default
    Fairly certain that sprint phones don't work outside the us.
    Sent from my EVO using Android Central Forums
  3. #3
    kg4icg's Avatar
    Posts
    Global Posts
    739 Global Posts
    ROM
    Stock JB
    Default Re: International Usage of EVO LTE
    EVO Design is the only world phone in the EVO lineup. All others are US only.
    pin#LPBUIFC8
  4. #4
    jwbekens's Avatar
    Posts
    Global Posts
    124 Global Posts
    Works in Canada, Puerto Rico, US Virging Islands. See here:
  5. #5
    Wait doesn't the EVO have a hidden sim card slot?? I remember reading on it or saw it from the tear down they did. Could be wrong but about 90% sure. What I don't get is why these phones still don't come with a sim card slot. I for one travel quite a bit but always have to end up using my gf photon. I'll search and post the link if im correct.
    I knew they worked in Canada and Puerto Rico but was hoping for the far east. I may just have to communicate via email/FB.
  7. #7
    Quote Originally Posted by MDteX View Post
    I know Japan networks use GSM, pretty sure China and HK are the same. With international roaming the EVO LTE should work, at least for voice calls and text. I was there a couple years ago with a Hero; it worked intermittently. Any time you have wifi available that should work too.
    Bear in mind international roaming can get really expensive. Might want to look into getting a GSM based Sprint phone; a Sprint store may have specifics on how to do so. Also recommend you check into a prepaid phone on another network at least for calls and text.
    Hope this helps; enjoy your trip!
  8. #8
    it doesnt work in Costa Rica, just got back from there
  9. #9
    Have used my evo 4g og in Israel- not cheap, but works fine, I think I had to set it up with Sprint the first to allow international roaming.
  10. #10
    As kg4icg stated, i believe the EVO Design was the only EVO that had world capabilities. I wish Sprint offered more world phones.To my knowledge these are the other world phones on Sprint, the Photon and iPhone 4S.
    yEzZiR! - samsung n400 w/camera > Sanyo mm7400 > Sanyo VM4500> Samsung Instinks > Palm pre > HTC EVO 4g
    jeravicious.wordpress.com
