I'm thinking of upgrading my Galaxy S5 to the unlocked LG G5. I was wondering if anyone could offer their opinions on the build quality. I typically carry my phone without a case in my front pocket. Is it likely to bend while in my front pocket? It seems really thin compared to my S5 and I know it's taller. I'm a short person and my S5 seems to find it's way to the side of my leg when I sit.
Thanks in advance,
Matt
I own one. Galaxy S5 to G5 here too! Actually theres a thread like this one...about build quality.
G5, it does not look like full metal bcoz of the coating. I have mine in a case. Just be careful , sand might get into your pocket. If u invest in a case, look for a thin one or else it might obstruct the wide angle lens when u take pics.
G5 is ok. The good, really loud speakers. Call quality , esp with full volume you'll turn deaf! Fast phone, the wide angle lens is nice , battery okey ,gets me through the day with hibernation app installed.
The not so good, mostly cosmetic flaws. The edges are sharp, well at least for me, thats why i put a case. Very hard to look for a screen protector. The removable modules has a small gap, esp when you're fond of battery swapping. Just bad quality control. This phone is like the Frankenstein of phones. No interesting modules (very expensive too). The always on screen very dim in broad daylight. Mine turns very warm when i use under the sun esp with full brightness where u will need bcoz its LCD screen. Notice the screen bleed on lower right.
Look at amazon reviews first. Read as much negative reviews, don't be afraid. I wish i did.
Well its really up to you, its your decision. There is the pixel phone from Google, there is the V20 from LG, if you want options. I hope you will choose the best phone.
