[ROM]CM10.1/PAC-rom jb 4.2.2 The JBC alpha build
thank you Redchigh and _alexkta .. indeed i did try both.. i just made another attempt and still no 3g .. my steps are bellow...
0. i wiped and cleaned everything as basic flashing goes (wipe data/factory reset, wipe cache partition. under advanced submenu, wipe dalvik-cache. uner mounts & storage submenu, format all partitions except the sdcard.
1. flashed: PAC_JB_4.2.2-v22.0.1_20130330-001202
2. flashed: gapps-jb42-20130307-KonstaKANG
3. flashed: virgin_fix_pac-rom-3-30
4. booted normal into rom until i reached the home screen...(i by passed google setups and didnt turn on wifi)
5. powered off back into recovery..
6. flashed: CronMod-INT2EXT+_signed
7. rebooted twice so far and still no 3g
Awesome work kraken. Yet more life to my Optimus v!
The combo of paranoid & cm is really fun to play with, I do miss some Cm niceties on my Nexus 7(PA).
I had a question I'm guessing some of you could help with - I'd like to strip as much as possible and replace it with my own apps (ie trebuchet & apex). Does anyone know offhand what apps are safe to get rid of? I know some of the stock apps seem to break things if you disable or remove and I'll play around with what I can disable safely later but hoping someone can get me started.
Sent from my Nexus 7 using Tapatalk HD
i tried the a28-cm-10.1-20130220-thekraven-LS670 rom as well without flashing the CronMod-INT2EXT+_signed ... still to no avail .. 3g worked on the stock rom but all the roms after cm 9.0 i never get 3g to work.. can you share the steps used and roms, gapps, etc used that have worked with you?
the other trick to try is to flash harmonia froyo, or the stock Rom, and let it run the activate app to reactivate your 3g. after it works again, go back into recovery, wipe /data and /cache and then flash pac or whatever again.
Is there somewhat of a consensus on the best stuff (gapps version, patches,etc) to flash for PAC on the Optimus V?
In fact, Leslie made a small froyo rom for utility work like this. It's called Rhode. Here's a link for you...
http://www.vmroms.com/index.php?topic=177.0
Sent from my LG-VM670
I too, as did others, had that issue with the CronMod Int2ext+. Try obi's script a few posts back. I'm using CronMod's older A2SD+ with no issues, but may try obi's script soon :D
Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
So I'm on a V, and evidently its time for a reflash.
Nandroids (clockwork, newest) aren't resetting back properly, and a few bugs are still sticking even though i wiped everything.
My boot screen freezes every time, unless i discharge the internal battery.
Gapps crashes exactly twice on every boot (the multi-dpi one)
Process system freezes on every boot, but i can click wait and it works.
Can someone suggest the winning combination of ROM, kernel, gapps, etc? With int2sd+ in not limited on space.
Also, if i were to use UOTkitchen to personalise, does this count as jellybean? Just wondering since cm10 themes don't load properly.
I see that there were some bluetooth fixes added to the new PAC build. Has anybody gotten BT to work on this?
Brabian
