Page 1 of 21 1234 ... LastLast
Results 1 to 25 of 512
Like Tree121Likes
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Default [ROM]CM10.1/PAC-rom jb 4.2.2 The JBC alpha build
    What's the JBC, you don't want to know. Haha
    Giving you something to play with. Fresh compile from sources. The JBC alpha builds are pretty much CyanogenMod 10.1 with very little tweaks. Really the system is too big, and I had the trim down the rom. Removed cmwallpapers, ringtones, boot animation, removed all languages except english.
    The other JB 4.2.2 rom is the PAC-rom. It is a mix of CM10.1, AOKP, and Paranoid Android roms.
    Working so far: wifi, usb mass storage, audio, video in browser, Google play, Youtube hq Include test 38 ics kernel. You can try other CAI kernels .
    Hint: to get dev settings, tap Build number 7 times
    BUGS: Wifi seems to eat the battery the most. Hdr camera mode will fc due to lack of memory, so just use regular picture taking.. Reboots and battery drain is expected. Livewallpaper isn't working. Bluetooth and tethering not working
    Changelog for build A11
    • fixed read baseband,made more system room,build using tiny configs, gapps mini3 has the latest Google play
    Changelog for build A12/a15
    • added offline charging,fixed lockscreen clock font,switched to gpu setting in the build.prop
    Changelog for build A17
    • RADIO, chronius widget,added virgin key fix and build.prop fix below. External eri.xml fix.
    CHangelog for build A24
    • Camera works, youtube glitches fixed, Added back bootanimation, battery bar, navigation buttons from KonstaT, fixed wifi signal bars from androidarm6, includes test 38 kernel now
    Changelog for build A25.... fixed wifi issues by removing sd-ext scripts, latest cm10.1 sync, removed some patches till next build.
    1/19/2013 gps patch... latest fixes below
    Changelog for build A26 ... Wifi is borked on a fresh install. So dirty flash over A25 for now. gps should be fixed. Latest cm10.1 sync as of the build date.
    Changelog for build A28 ... latest cm10.1 sync, now JB 4.2.2. HDR camera mode, wifi should be fixed on a fresh install. Reboot menu moved to Developer settings. No other thunderc fixes.
    See the CAI 2nd post for new kernels test 39 and 40.
    Pac Rom is on page 6. A mix of AOKP, CM10.1, and Paranoid Android. http://forums.androidcentral.com/lg-...ml#post2606677
    [BOX=Downloads]
    Download A28
    Newer JB 4.2 gapps from KonstaT:
    See post 218 for Usb tethering fix [ROM]CM10.1/PAC-rom jb 4.2.2 The JBC alpha build
    [/BOX]
    Thanks to androidmeda and androidarm6 devs
    Thanks to LeslieAnn, Bobzhome, tdm, drew, KonstaT, and thunderc devs.
    Kernel source:
    JB 4.2 source:
    Attached Thumbnails Attached Thumbnails [ROM]CM10.1/PAC-rom jb 4.2.2  The JBC alpha build-device-2012-12-25-010619.png   [ROM]CM10.1/PAC-rom jb 4.2.2  The JBC alpha build-device-2012-12-25-010711.png
    Attached Files Attached Files
    Thanked by 35:
    + Show/Hide list of the thanked
    Axe, gtdappert, glenesis and 18 others like this.
  2. #2
    epidenimus's Avatar
    Racer of Elevators
    Posts
    ROM
    Paranoid Android / CM7
    Default Re: [ROM] CM10.1 jb 10.2 The JBC alpha build
    Un-F-ing believable. Amazing how this little phone lives on thanks to you. I might have to charge up just to try it out. Cheers!
    (Firsties!)
    If you are inclined to spend a lot of money and want a pretty trophy with which to pass the next few years of your life that talks to you in a condescending voice, can't navigate to save its life, expects full control over all you do, demands $13 for a $3 purchase, allegedly has a single recessed button, needs an expensive computer and a credit card to do anything, hates your music and has purses designed just for it...
    Get married to someone you hate... or get an iPhone.
    New to LG's premium Android phone? Check out the Optimus S Welcome Guide.
    Used ROM Mangler on your Optimus S and having problems? Try this.
    Va1ha11a likes this.
  3. #3
    Thraeryn's Avatar
    DEVASTATOR
    Posts
    ROM
    Cool As Ice alpha 14
    Merry Christmas to us! Thanks a ton for another step forward for our little phones.
  4. #4
    sonicbluemustang's Avatar
    Posts
    ROM
    Cold As Ice
    I cant bring myself to trade up and get a new phone. Thanks Kraven somethin to play with.
    Axe likes this.
  5. #5
    hlxanthus's Avatar
    Posts
    ROM
    RasbeanJelly/DanteRom v4
    Nice @thekraven!! You never cease to amaze
  6. #6
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Wonder why my WiFi doesn't work... Im going to do a bringup of the p500 device files, I think I'm missing stuff.
    Sent from my HTCEVOV4G using Android Central Forums
    Guess whos coming back!
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Quote Originally Posted by sellers86 View Post
    Check how full the system partition is.
    To narrow it down. Flash my cai test 23 kernel. If wifi works it's the kernel. If not try my boot.img and modules. If it works, then it's the ramdisk inits.
  8. #8
    sellers86's Avatar
    Posts
    ROM
    CNA/CM9/Mirage
    Quote Originally Posted by thekraven View Post
    Thanks for the advice, I appreciate it
  9. #9
    thewraith420's Avatar
    Posts
    ROM
    Changes Daily
    Very cool kraven! I need service so I wont be flashing yet but ill definitely be interested to see where this goes. Thanks for your ongoing work to keep our ageing phones up to date
    Sent from my VM670 using Tapatalk 2
    onebigjoke likes this.
  10. #10
    pellik333's Avatar
    Posts
    ROM
    Quattrimus ICS - AOKP
    Can we vote thekraven developer of the millennium? Thanks for all you do man. I love your work and Jelly Bean thus with this thread I now would like to propose to you.
    Sent from my Optimistic S using Tapatalk 2
  11. #11
    Noob question: Can this ROM be flashed onto Optimus V?
  12. #12
    I moved on to the DNA last month, but this thread is another example of why I loved my Opti S for as long as I had it. Great work Kraven!
  13. #13
    flapjack.fiasco's Avatar
    Posts
    ROM
    Cold As Ice - Alpha 19e
    Quote Originally Posted by Promethium97z View Post
    Yeah, but MMS probably wouldn't work, and some hard keys would be backwards.
    This space intentionally left blank.
    Thanked by:
  14. #14
    Posts
    ROM
    Changes Daily
    Quote Originally Posted by flapjack.fiasco View Post
    Lol mms is a little moot at this point in the game since sms and calling aren't even working yet. Home and Menu keys will be swapped.
    Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ firmware
  15. #15
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    What's up with radio? and Thanks!!!
  16. #16
    Thanks kraven!!!
  17. Thread Author  Thread Author    #17
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    It might JB 4.2.1, and no old CDMA ril support. The frameworks Phonefactory.java is missing a bunch of cdma stuff.
    Thanked by:
  18. #18
    Hi guys, I can not recover imei, I also tried using recovery efs but nothing, who can help me?
  19. #19
    BobZhome's Avatar
    Posts
    ROM
    CM9/10
    Thanks for the help and support you give out!
  20. #20
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Default Re: [ROM][WIP] CM10.1 jb 4.2.1 The JBC alpha build
    Sweet! Can't wait for full version with radio
  21. Thread Author  Thread Author    #21
    thekraven's Avatar
    Posts
    ROM
    kraven cm7/CM9
    Got radio working, uploading build 17
    Axe and Zakman like this.
  22. #22
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    Testing now, thanks kraven
  23. #23
    exProphecy's Avatar
    Posts
    Global Posts
    96 Global Posts
    ROM
    Cold.As.Ice CM9/Kernel 21
    What are the steps to fixing for optimus v? I'd rather do it myself than to keep bothering for one in the future haha
  24. #24
    Zakman's Avatar
    Posts
    ROM
    CM10/BobzHome's 4.1
    It works on the optimus v just have to change keys around, build.prop and carrier label.
  25. #25
    exProphecy's Avatar
    Posts
    Global Posts
    96 Global Posts
    ROM
    Yeah I know it functions i was asking the steps on changing the keys build.prop etc. I'm pretty certain I can figure out how to fix the build.prop but how do i switch the hardware keys?
  1. [ROM][CM10][JB] Euroskank JellyBro
    By tcapote in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 06-13-2013, 04:53 PM
  2. Thinking about Flashing to the CM10 JB Rom... 2 questions first
    By Azwizzard in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 10-15-2012, 12:21 PM
  3. [ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
    By Dark_Knight2 in forum Epic 4G Touch Archived ROMs and Hacks
    Last Post: 08-25-2012, 11:10 AM
  4. [ROM][AOSP][CM10][JB][7/25]Unofficial Official Cyanogenmod
    By SeigaGen in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 08-04-2012, 02:58 PM
  5. Desire ROM ported to the N1 (Alpha 10 now Live)
    By edizzle in forum Google Nexus One Rooting, ROMs, and Hacks
    Last Post: 03-10-2010, 07:32 PM
