[ROM]CM10.1/PAC-rom jb 4.2.2 The JBC alpha build
thekraven
1,407
1,148
What's the JBC, you don't want to know. Haha
Giving you something to play with. Fresh compile from https://github.com/androidarmv6 sources. The JBC alpha builds are pretty much CyanogenMod 10.1 with very little tweaks. Really the system is too big, and I had the trim down the rom. Removed cmwallpapers, ringtones, boot animation, removed all languages except english.
The other JB 4.2.2 rom is the PAC-rom. It is a mix of CM10.1, AOKP, and Paranoid Android roms.
Working so far: wifi, usb mass storage, audio, video in browser, Google play, Youtube hq Include test 38 ics kernel. .
Hint: to get reboot options, dev and kernel settings, tap Build number 7 times
BUGS: Wifi seems to eat the battery the most. Hdr camera mode will fc due to lack of memory, so just use regular picture taking.. Reboots and battery drain is expected. Livewallpaper isn't working. Newer builds with the 3.0 kernel will have charging indicator not working yet. Either charge in recovery or flash the latest 3.0 kernels from bigsupersquid in his kernel thread.
CHangeloge for Build 6 JBC CM10.1 build. 7-15-2013
  • Includes latest security fixes from cyanogen ,
  • latest bigsupersquid 3.0 kernel with security patches Gerrit Code Review and working accelerometer. Built now using virgin's keypad in the kernelsource. This just eases flashing any newer kernels from bigsupersquid. Note: The rom already has the sprint keypad fixes. .
  • resize nav bar option
  • lots of bluetooth work from androidmeda, untested.
  • wifi hotspot work from androidmeda, might need a reboot to turn off/on again
  • wiifi should wake from deep sleep now.
  • Includes halo notifications how to use halo Paranoid Android's HALO - Overview - YouTube
  • Latest sync with cyanogen and androidarmv6 as of today, it might be cm10.2 now, just needs the version number bumped.
  • Newer virgin fix untested http://forums.androidcentral.com/at...ha-build-virgin.fix4.3.0kernel.jbc-cm10.1.zip
  • older 2.6 kernels won't boot with this.
Pac Rom is on page 6. A mix of AOKP, CM10.1, and Paranoid Android. http://forums.androidcentral.com/lg...1-jb-4-2-2-jbc-alpha-build-6.html#post2606677
A big thanks to bigsupersquid for his development of the 3.0 kernel. Send thanks and support his work here: http://forums.androidcentral.com/op...android_kernel_lge_msm7x27-3-0-x-3-0-8-a.html
Thanks to androidmeda and androidarm6 devs
Thanks to LeslieAnn, Bobzhome, tdm, drew, KonstaT, and thunderc devs.
Kernel souce: https://github.com/TheJBC/android_kernel_lge_msm7x27-3.0.x
Kernel source: https://bitbucket.org/thekraven/iscream_thunderc-2.6.35-rebase
JB 4.2 source: https://github.com/androidarmv6
Re: [ROM] CM10.1 jb 10.2 The JBC alpha build
Un-F-ing believable. Amazing how this little phone lives on thanks to you. I might have to charge up just to try it out. Cheers!
(Firsties!)
Merry Christmas to us! Thanks a ton for another step forward for our little phones. :D
I cant bring myself to trade up and get a new phone. Thanks Kraven somethin to play with.
Nice @thekraven!! You never cease to amaze :D
Wonder why my WiFi doesn't work... Im going to do a bringup of the p500 device files, I think I'm missing stuff.
Sent from my HTCEVOV4G using Android Central Forums
Check how full the system partition is.
To narrow it down. Flash my cai test 23 kernel. If wifi works it's the kernel. If not try my boot.img and modules. If it works, then it's the ramdisk inits.
Thanks for the advice, I appreciate it :)
Very cool kraven! I need service so I wont be flashing yet but ill definitely be interested to see where this goes. Thanks for your ongoing work to keep our ageing phones up to date
Sent from my VM670 using Tapatalk 2
Can we vote thekraven developer of the millennium? Thanks for all you do man. I love your work and Jelly Bean thus with this thread I now would like to propose to you.
Sent from my Optimistic S using Tapatalk 2
I moved on to the DNA last month, but this thread is another example of why I loved my Opti S for as long as I had it. Great work Kraven!
Yeah, but MMS probably wouldn't work, and some hard keys would be backwards.
Lol mms is a little moot at this point in the game since sms and calling aren't even working yet. Home and Menu keys will be swapped.
Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ firmware
What's up with radio? and Thanks!!!
It might JB 4.2.1, and no old CDMA ril support. The frameworks Phonefactory.java is missing a bunch of cdma stuff.
Hi guys, I can not recover imei, I also tried using recovery efs but nothing, who can help me?
Re: [ROM][WIP] CM10.1 jb 4.2.1 The JBC alpha build
Sweet! Can't wait for full version with radio :D
Momentum-Optimus
