OK, here we go, I ported over the almost final version of my Honeycomb theme from the HTC Hero, still need to theme the icons out to the new honeycomb ones.
I know this will work on ThundeRom, not sure about any others so if you'd like to test it out on any others feel welcome to and i'll update this post to reflect it.
Instructions:
1. Boot into recovery and make a backup
2. If coming from another theme, I'd suggest wiping your cache
3. Flash theme
4. Reboot
5. Enjoy
ThundeRom V1
Download
CM7 Version: 2.0
Updated: 4/02/11
Instructions:
1. Download both apks
2. Place both of them on the root of your sd card
3. Using a file explorer, install "InstallFirst.apk" then install HoneycombComboS.apk immediately after.
4. Open theme chooser
5. Select HoneycombS
6. You will get this error: "Sorry, this theme is missing assets for your device's screen size." Hit apply anyway
7. Reboot
8. Enjoy!
Install First apk
HoneycombComboS apk
Alpha 7
OK, here we go....
This is a port of my cm6.1 theme now for CM7
I redid a few images, mainly the battery and a few odds and ends....themed out Music, Genie, DeskClock and Power control widgets.
there are a few more things i'd like to do with this....
*edit* now fixed and with only 1 apk
Instructions:
1. Download apk
2. Place on the root of your sd card
3. Using a file explorer, install "alpha7_signed_11.apk"
5. Select alpha7
7. Reboot
8. Enjoy!
Download: Alpha7
Addons:
Included in the attachments are several wallpapers, docks and if you use it, a widgetlocker theme (alphaextras). You do not flash....it's a wallpaper/docks pack that you unzip and place on your sdcard. Change accordingly!
plus there is a blank icon to use with the docks in a seperate attachment
*NEW*
What is this?
This is a theme based off the popular MIUI rom
What it's not....
This is just the look, not the features the rom has...
If you would like more of an MIUI look, I would suggest downloading
Go Launcher EX
Go Contacts
Go SMS Pro
What is themed:
Framework and system ui
System icons
Todo list
Theme dialer
theme Contacts
a few more odds and ends
Instructions:
1. Download "Orion_signed.apk" located in the attachments of this post.
3. Using a file explorer, install "Orion_signed.apk"
5. Select Orion
7. Reboot
8. Enjoy!
Download: Orion
Additional:
Also attached to this post is a zip file with some wallpapers and the dock used in the screenshot...if you'd like to use them just unzip to your sd card then change accordingly
Instructions:
3. Flash theme
4. Reboot
5. Enjoy
ThundeRom V1
Download
CM7 Version: 2.0
Updated: 4/02/11
Instructions:
7. Reboot
8. Enjoy!
Install First apk
HoneycombComboS apk
Alpha 7
OK, here we go....
Instructions:
1. Download apk
5. Select alpha7
7. Reboot
8. Enjoy!
Download: Alpha7
Addons:
*NEW*
What is this?
What it's not....
Go Launcher EX
Go Contacts
Go SMS Pro
What is themed:
System icons
Todo list
Theme dialer
theme Contacts
Instructions:
5. Select Orion
7. Reboot
8. Enjoy!
Download: Orion
Additional:
